HELP! 03 warrior sprung a leak!
Old May 24, 2004 | 03:52 PM
gotanutloose's Avatar
Default HELP! 03 warrior sprung a leak!
Hey Guys, my 2003 warrior started to leak a little (about the size of a dime) oil right behind where the bottom half meets the top half. It will even leak here if it is not running. It doesn't seem to run any worse. I am going up north this weekend for a 3 day trail ride and I want to make sure it is not going to clunk out on me. Any suggestions on what this could be? Is there anything I can "tighten" to make this stop. I am trading it in to get a new yfz in June and I don't want to have to rebuild before I do this. Please Help. Thanks in advance.
BTW the atv only has about 70 hours on it is this normal?
Old May 24, 2004 | 04:06 PM
BALDMIKE's Avatar
Sounds like you may want to snug tight all surrounding nuts and bolts and see if that helps.....
Old May 24, 2004 | 05:02 PM
warrior68man's Avatar
try to tighten the bolts, If that doesn't help, you will need a new gasket. There is somthing called Seal-a-leak or somethign you can spray on the side of your motor and it will stop oil leaks...I know, I use it all the time....cars, dirtbikes, and even my warrior.
Old May 24, 2004 | 05:38 PM
What Bolts exactly should I Tighten?
Old May 24, 2004 | 06:27 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
ALL the bolts... on the case i think..
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
wrencher82
Sep 24, 2015 03:39 PM
