sprocket teeth
Old Jun 17, 2004 | 06:03 PM
lotsaponies's Avatar
Default sprocket teeth
to get more acceleration or top speed, do i need to remove or add teeth? how many + or - ? Front or rear sprocket? [img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 17, 2004 | 07:35 PM
bansheeesmoker's Avatar
For more acceleration go down in the front or up in the back, but you will drop your top speed around 5mph to a tooth in the front. 1 tooth in the front is equal to 3 in the back. for more top speed go up in the front or down in the back. dont start changing your rear sproket untill your close to where you want you power range at. then buy a rear if you want to get inbetween where your at. Use the rear to fine tune your gearing. Rear sprockets are like 50 -60$ as a front will cost 20-30$. Also its good to replace both your sprockets and your chain if your old ones look worn out but not required. hope this helps.
Old Jun 17, 2004 | 09:26 PM
Thank you bansheeesmoker, youve helped a lot.
Old Jun 18, 2004 | 10:51 PM
hondaguy13's Avatar
to gain speed go up on the front sprocket or down on the back sprocket to gain bottom end but lose topend go down on the front or up on the back
Old Jun 19, 2004 | 05:04 PM
mahnster's Avatar
You can get primary drive sprockets from rocky mountain for $7 a front and $15 for a rear.
Bratman2
Aug 6, 2022 01:42 AM
flyin-lowe
Dec 1, 2017 03:18 AM
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
