01 AC 400 Electical Problem
Old Jun 21, 2004 | 03:44 PM
spieratt's Avatar
Default 01 AC 400 Electical Problem
I have an '01 Arctic Cat 400. Recently the machine stopped abruptly while pulling a heavy load. I checked and found that the 10A low fuse was blown. Also the Ignition fuse blown. Replaced both, the machine now starts but immediately blows the 10A low fuse. What could be causing this? What does the 10A fuse control?
Old Jun 22, 2004 | 09:59 AM
tta583's Avatar
Don't know off the top of my head. Did you look in the manual?
Brent
Old Jun 23, 2004 | 12:10 AM
Win3855's Avatar
Some machines have had a problem with the wire harness going from the handlebars to the frame. It has rubbed the wires and they have grounded out,blowing the fuses. Might be a place to look.
Old Jun 23, 2004 | 09:15 AM
snowbuzzard's Avatar
Also check under the seat. In some cases a couple of the wires can get jammed in the mounting holes for the front of the seat. Also the sift linkage will bump up against a wire bundle under the seat and wear through shorting the wores. Some tie-wrap applications can pull tehse wires out of the way.
Old Jun 23, 2004 | 10:50 AM
CatsRule's Avatar
When my voltage meter went i blew a few fuses in my 01 300. You could take a look at that.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
