Warn 424 shift kit
Old Jun 30, 2004 | 01:08 PM
jreece's Avatar
Default Warn 424 shift kit
What is this and is it worth buying? ---how much?
Old Jun 30, 2004 | 01:59 PM
LittleBill's Avatar
yes, switches from full time 4x4 to 4x2 with a manual lever, around 230 on ebay
Old Jun 30, 2004 | 02:01 PM
jreece's Avatar
ok thanks, i might have to look into it.
Old Jun 30, 2004 | 03:52 PM
RedGoblin's Avatar
Make sure when you install the cable, you leave as much straighter cable as possible and certainly no kinks. I'm having difficulties with mine because I think I have too much of a curve coming from the handle going into the plastic where it goes back to the driveshaft.
Old Jun 30, 2004 | 04:00 PM
LittleBill's Avatar
yea long bend works best, i have the cable loosly secured on mine, although goblin you prolly would have better luck engaging from a get go, it won't engage in 2 wheel sittin still
Old Jun 30, 2004 | 05:44 PM
RedGoblin's Avatar
No, I've tried all the tricks in the book. There's either something wrong with it or there's too much tension on the cable somewhere. I'll check it out sooner or later, but just haven't yet. For some reason, if you lift the front tires just off the ground, it'll work fine.
95wolv
Sep 27, 2024 12:00 PM
Jeff Roper
Feb 1, 2022 11:48 AM
panicmanic
Sep 28, 2015 12:59 PM
Clint Russell
Sep 25, 2015 03:20 PM
BigCam
Sep 16, 2015 01:53 AM
