dynotec gas requierments
Old Jul 8, 2004 | 11:33 PM
travelor's Avatar
Default dynotec gas requierments
Do you need to run higher octane gas with the cdi? Dg says with thier module and a key you need to run premium. But it is the same advance timing as the cdi from dynotec.
Old Jul 9, 2004 | 04:41 PM
STAKK's Avatar
Mine runs fine on 89........
Old Jul 9, 2004 | 06:56 PM
FifthHorseman's Avatar
Dyna themselves say 89 i believe. I always thought that high compression is the reason for using premium gas.
Old Jul 9, 2004 | 08:06 PM
kawiyowee's Avatar
Mine runs fine on anti-knock index of 87 with or without the new cdi (that is the recommended # in al l the Prairie owners books). Whatever your owner's book says, (probably 87) I believe you can use that with no problem from the new cdi. Also, I seem to remember a post from Scott (dynatek) that 87 was ok.
Old Jul 10, 2004 | 03:19 AM
travelor's Avatar
Don from dg racing was recomending using priemium with the 4 degree key and dg3, I thought if the dyno cdi dosen't need it ,why would the module and key need it?
reconranger
Mar 2, 2009 07:32 AM
turqui
Apr 24, 2007 05:39 PM
beaty
Apr 12, 2007 02:30 PM
Scramrider52
Aug 4, 2004 04:37 PM
mojave4
Apr 14, 2003 08:17 PM
