not a quad
Old Jul 16, 2004 | 10:00 AM
joepa167's Avatar
Default not a quad
ok we have a 270 micro with a ESR 270 motor just got it rebuilt put it on fired it up and its blowing water out the over flow and the pipe i know its not a quad but the motors are the same any one have a clue why its doing it ????? thanks JPH
Old Jul 16, 2004 | 10:43 AM
sickmojave's Avatar
Default not a quad
I would guess that you have a bad head gasket [img]i/expressions/face-icon-small-sad.gif[/img]
Old Jul 16, 2004 | 10:44 AM
69HemiGTX's Avatar
US Army lifer
Default not a quad
Check the head gasket/o-rings. That's where your problem should be.
Old Jul 16, 2004 | 10:47 AM
joepa167's Avatar
Default not a quad
well see that the thing they where bad so we got new ones and it stell did it
Old Jul 16, 2004 | 11:58 AM
69HemiGTX's Avatar
US Army lifer
Default not a quad
By saying you've got "new ones," I assume you are talking about o-rings. That means you have a CR engine. Big difference between it and the ATC/TRX engine. Anyways, if it is still leaking with new o-rings, check the receiver grooves in the head and cylinder and make sure there are no gouges in them. Also, check to make sure that the head is absolutely flat. If it warped, it will not seal correctly when torqued down and cause a leak.
Old Jul 16, 2004 | 12:31 PM
joepa167's Avatar
Default not a quad
we done all that also and its stell doing it
Old Jul 16, 2004 | 08:58 PM
TractorPacker's Avatar
Do you have a balloon?
Default not a quad
Did the sleeve drop in the cylinder. If you can catch your finger nail on it, it dropped. Check that, you may have to get the cylinder re-decked.
Chillibean
1) Engine problems..
Sep 5, 2020 04:02 AM
Frisky2050
Apr 9, 2020 11:19 AM
greg74
Sep 10, 2019 03:03 PM
Ashley S
May 29, 2017 10:54 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
