12 volts
Old Jul 28, 2004 | 11:09 PM
soon2bBlaster's Avatar
Default 12 volts
does a blasters light system run off of 12 volts if so could i buy a cheap pair of walmart lights that run off a 12 amp power supply and hook them up temporarily
Old Jul 28, 2004 | 11:39 PM
1LeSSRaptor's Avatar
Default 12 volts
Yes, the blaster uses a 12 volt battery system. Amperage and current are two different things though. Get a light setup for 12 volts but look to see how much current it draws. You don't want to go too high because it will drain your battery but if you go too low, it might not be bright enough. Look for something about in the middle.
Old Jul 28, 2004 | 11:41 PM
Default 12 volts
^ Sorry, I meant voltage and amperage. Get the 12 volt, but check the amperage.
Joe454
Nov 20, 2020 01:19 PM
speedbuff
13
Nov 11, 2020 10:16 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
