First time Polaris owner Sp600
Old Aug 13, 2004 | 11:08 AM
TennesseeTider's Avatar
Default First time Polaris owner Sp600
Hello Everyone!
I am the proud new owner of a 04.5 Sportsman 600!
Never owned Polaris before, but so far the thing is simply awesome!
A couple of quick questions, after the warranty expires, is a Heelclicker really worth installing? If so what difference will I feel?
Thanks!!
Old Aug 13, 2004 | 11:45 AM
MnFriesen's Avatar
sorry cant help you with your question but congrats on the purchase and welcome to the forums [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 13, 2004 | 02:13 PM
sp600towtruck's Avatar
Just changing the primary spring up one size will make a big difference on take off.
Old Aug 13, 2004 | 10:22 PM
Where can I buy a new primary spring? What will that particular spring do? Will that allow for lower rpm engagement?
thanks! As you can tell, I am new to the world of automatic PVT belt driven systems. I know next to nothing about them.
All help is appreciated!
Old Aug 13, 2004 | 10:46 PM
Farmr123's Avatar
Most primary springs that improve performance, create a higher RPM engagement point. If you want performance increased, as well as immediate off-idle performance, the HeelClicker is probably the better way to go, although the more expensive way.
Maybe keep it stock during warranty, so there will be no issues there, though. That way the dealer can't say anything you did caused problems.
Old Aug 14, 2004 | 01:50 AM
I got the gray spring with the white stripe on it right from Polaris for around $18. I know the mechanic at the dealership where I bought mine, and he suggested that particular spring with heavier weights, which were $33 for all three. It launches hard now, pulling up the front end real good, but if I still want to putt slow around the yard, it still does that fine too.
Old Aug 15, 2004 | 07:37 AM
Predator03's Avatar
Welcome Tennessee Tider..
On other year models, the factory rear spring setting is set at it's softest....if this is the case with your, tighten it two clicks...you will notice a remarkable difference....
As far as the heelclicker kit and such....it's not a race quad......buy a sport quad to go along with it...
Do you ride at Windrock?
wildbill59
Jun 20, 2015 02:26 PM
DOAinNY
Jun 11, 2015 10:34 PM
cornermike
May 28, 2015 09:47 AM
ragewraps
May 27, 2015 08:07 AM
ATV_MAN
Aug 23, 2000 12:00 PM
