Traxter won't shift out of reverse
Old Aug 19, 2004 | 11:33 PM
runkeldc's Avatar
Default Traxter won't shift out of reverse
Traxter won't shift out of reverse or forward while the engine is running. Shifting lever works ok when the engine is off. It will go from park to reverse but after that I can't get it to move. If I start it in forward ( I don't know if it should do that) I can't move the shifter out of forward. Any idea what's going on here?
Old Aug 20, 2004 | 08:06 AM
chengdave2003's Avatar
I'm not at all familiar with Traxter's, but my wife's Outlander had similar symptoms. The transmission linkage turned out to be out of adjustment....
Dave
Old Aug 21, 2004 | 11:39 AM
4rATVahrer's Avatar
Hi runkeldc,
check the idle speed first. If it is too high the clutch will not seperate so you have problems shifting the Reverse/H/L gear. You may adjust idle speed at the left side underneath the carburator. I hope this will help.#
greetings from Germany
Old Aug 22, 2004 | 02:38 PM
runkeldc's Avatar
It was the ilde speed. Thanks.
95wolv
Sep 27, 2024 12:00 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
Clint Russell
Sep 25, 2015 03:20 PM
BigCam
Sep 16, 2015 01:53 AM
