one wheel drive??
Old Aug 22, 2004 | 10:07 PM
hdnvn's Avatar
Default one wheel drive??
This past evening I took my Polaris 500 out for a ride on the street in front of my house as I do not happen to have a convenient acre or to to cruise on. Anyhow, twice when starting out in Hi, two wheel drive the unit felt as if it was pulling to the right really hard. Once in reverse as well. Tire pressure was even although it felt as if I had a flat tire so extreme was the pull. I just bought the quad, havnt even hadd the thing in the woods yet. I bought it used with a little over a 100 miles on it. Three days ago I put a lft kit on just the front and made sure that my struts bottomed out in each one of the strut housings. The problem disappeared after ptting the unit in reverse and then foward again, same when it was in reverse (put it in forward and then reverse) Any one out there had a similar probelm? Thanks, hdnvn
Old Aug 22, 2004 | 10:58 PM
tyler711's Avatar
As usual, i have no idea wha i'm talking about, but:
I think that problem is when one front hub engages, making the quad turn sharply in one direction. When you change directions, the caught hub releases. But I don't know why yours would do it in 2wd, you'd hafta get someone with a brain to answer that one lol.[img]i/expressions/face-icon-small-blush.gif[/img]
Old Aug 23, 2004 | 08:16 PM
rmkcac700's Avatar
whatever side the bike is pulling to is the side that has the problem in the hub. my cure the issue by changing the oil, but most likerly the hilliard lock washer is enguaging the hub on its own, i would like more details to help u out more
Old Aug 23, 2004 | 09:33 PM
hdnvn's Avatar
I'm not really sure whether its a drive train issue or a sticking brake issue. it was pulling in two wheel drive and the pulling was definitely in the steering, not the rear end. Eve had a brake stick on these things? Hdnvn
Old Aug 23, 2004 | 09:35 PM
DGScrambler400's Avatar
try changing your front hub fluid. If if feels like one of your front wheels is engaging, which could feel like the brake on one side is engaged, change your front hub fluid, and the problem will MOST LIKELY be fixed.
Old Aug 23, 2004 | 10:26 PM
hdnvn's Avatar
I'll try changing my front hub fluid..as soon as someone tells me how. I didnt even get a manual with the bike...whats involved??
Old Aug 24, 2004 | 08:27 PM
rmkcac700's Avatar
what year of a atv it is. hub oil can be purchased from ur dealer, and use the drain plug on the outer hub. whan filling it have the plug hole set at 4 or 8 oClock for full levels
Old Aug 24, 2004 | 08:49 PM
you dont have to go to your dealer to get the fluid, Mobil 1 (or other good brand, i use Citco) Automatic Transmission Fluid (ATF) works just as well, for probably a fraction of the cost. YOu said that if you put it in reverse than forward, the problem is gone, so there is a 99% chance of the oil being the problem. I am not sure if the front hubs on Sportsmans (im guessing that is what you have) is the same as the scramblers, so i cant help with the changing part.
Old Aug 24, 2004 | 08:55 PM
RAJ's Avatar
RAJ
I had the same problem, I changed the oil and it took care of it. BUT just like they said make sure you add the right oil......or you will have problems.
Old Aug 24, 2004 | 09:30 PM
hdnvn's Avatar
I have an 03 sportsman 500 HO. How do I change my hub fluid?
jrubicon
Where to Ride
Oct 8, 2015 01:05 PM
cody500ho
14
Aug 14, 2015 05:03 PM
toonces
Aug 5, 2015 05:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 18, 2015 07:51 AM
