450R Problem
Old Aug 24, 2004 | 06:10 PM
TRXRACERs's Avatar
Default 450R Problem
I have a '04 Trx 450r. I just got it pry about 2 weeks ago and everytime i get it out when i first go to ride when its really cold, i choke it, and let it idle then unchoke it and let it idle that way for a while. EVERYSINGLE time i pull the clutch in and put it in gear it stalls but it only happens when its very cold. Do i need to let it warm up a little bit more???or just let it go and start it after it stalls cuz after that it is fine.!!!!!!!!!!
Old Aug 24, 2004 | 06:19 PM
briansgi's Avatar
Adjust your clutch!
Old Aug 25, 2004 | 02:59 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Your clutch may be tight now, but it will loosen up soon enough all on its own. Just rev it a little more before you pop it in gear.
Old Aug 25, 2004 | 03:19 AM
CroBiker's Avatar
u have to remember that the 450r has a very fast first gear, so unless u feather the clutch quite a bit, or rev higher, until u've ridden it a bit it wants to stall like that. every quad is easier to stall when its cold, that's another factor as well. i used to have that problem, but don't anymore since i've worn out the plates a lil bit.
Old Aug 25, 2004 | 11:09 AM
odysseyjunk's Avatar
13t sprocket........i hardly ever stall mine anymore
Old Aug 25, 2004 | 11:18 AM
Lancester's Avatar
Who did your proting and what did it cost? Also, did you notice any difference going from the stock 10.5 to 1 piston to the 11 to 1? Thanx.....
Old Aug 25, 2004 | 07:36 PM
PUSHINTHELIMIT's Avatar
If you look at his signature again you'll see that the high compression piston and porting are done on his big red 200s 3-wheeler..
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
