400at clutch slippin
Old Aug 26, 2004 | 05:25 PM
04rancherwales's Avatar
Default 400at clutch slippin
hey guys. i think my clutch is startin to slip bad but how do i tell. it does make a funny slippin almost grindin sound once in a while.
Old Aug 31, 2004 | 02:24 AM
cals400ex's Avatar
put it in the upper gears and hit the gas. if you just hear the engine increase in rpm but your not going faster, it is slipping. you can smell the oil too. if it smells really burnt, more than likely the clutch needs replaced.
Old Aug 31, 2004 | 02:43 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
OK, this bike is an AUTOMATIC, so it doesn't have a clutch per se. I am assuming it might have some kind of centrifugal clutch that kicks in when the engine reaches a certain speed??? That what you are refering to? If so, isn't it adjustable? If it is a grinding sound, might be something worse!
Old Aug 31, 2004 | 04:06 PM
cals400ex's Avatar
sorry about that, i saw 400 and i assumed it was on a 400ex.
Old Aug 31, 2004 | 05:18 PM
hondabuster's Avatar
Check the oil level, it may be too low.
Old Aug 31, 2004 | 08:04 PM
MIDGET's Avatar
Did you have the ecm recall done? Call you dealer if you did not. They might cover your clutch if you did not the the recall done yet.
Old Sep 1, 2004 | 05:27 PM
thanks guys i havn't taken it back for ecm change but am planin on gettin it checked out. i have been thinkin bout a clutch kit but am worried bout it? should i be
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
