warrior jetting question
Old Aug 26, 2004 | 10:07 PM
suk4's Avatar
Default warrior jetting question
My 87 warrior has a suppertrapp racing pipe and i drilled 4 1 inch holes in the airbox lid. On top end when it wide open it bogs. i put a new plug and it didnt help do you think it needs to be rejetted because it was never rejetted with the slip on. if so waht size jet should i go.i am also going to put a k&n air filter so will it need a different jet with the kn also. thanks
Old Aug 27, 2004 | 12:47 PM
NLWarrior01's Avatar
If you have put on a pipe and modified your airbox you will definitely need to re-jet.
Depending on what elevation you're at you will require different jets from other Warriors with the same setup as you have.
I'm currently working on jetting my Warrior. and here's what I have so far:
Uni Filter and FMF Powercore IV Muffler
Main Jet 155 (stock is 145)
Pilot Jet 45 (stock is 42.5)
Airbox closed
Fuel Mix screw 2-1/2 - 3 turns out.
I did have a 160 main in and even with the airbox off it was running too rich, so I'm down sizing to the 155. Haven't had the chance to try that out yet.
The stock pilot was lean so I replaced it with a 45, and even with the airbox lid on, it's too lean so I'm currently looking for a 50 pilot.
The problem you're having is that the engine is leaning way out to the point that there's far too much air for the amount of fuel you're delivering. Riding like that for a prolonged period will damage your engine badly and cost you a lot of money.
Old Aug 27, 2004 | 01:06 PM
TrailBlazerguy250's Avatar
my warrior w/ the FMF Titaniam 4 full pipe w/ no air box lid has a 150 main jet and a 42.5 piliot
Old Aug 27, 2004 | 03:49 PM
DS650BajaRunner's Avatar
Hey Trailblazer what happened to the E-Series?
Old Aug 27, 2004 | 04:28 PM
accidentaly order a univeral White bros and thought for $240 its a way better deal to get a full FMF
Cole Hadden
Jun 15, 2025 09:05 AM
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
Reactant
Jul 16, 2015 10:29 PM
