P700 Front Drive Shaft
Old Sep 5, 2004 | 09:07 AM
Cuda440's Avatar
Default P700 Front Drive Shaft
Has anybody pulled the front drive shaft on a P700? Is it as easy as the service manual makes it sound? I was thinking of pulling the shaft to enter the 2wd class on my next mud bog after I run the 4wd class. I know if I pull the shaft I need to find something to cover or plug the holes/boots. Any info on this would help? Thanks
Old Sep 5, 2004 | 11:46 AM
redbruteforce's Avatar
couldn't you remove the fuse that controls the 4wd actuator?
Old Sep 5, 2004 | 01:50 PM
Cuda440's Avatar
The official at the track requires that he see's the shaft is removed. I guess they think your gonna cheat somehow. According to the service manual you do not need any tools. Just remove two rubber o-rings, slide the boot off the groove and remove shaft. Guess I'll have to try it. It would be nice to run in the 2wd class and show some of them what a P700 has in it.
Old Sep 5, 2004 | 09:36 PM
SHOTGUN's Avatar
I had mine out and back in, (just this weekend). It's got a spring the keeps it pushed ahead in a spline. roll the O ring back and then the boots back and pull the shaft back towards the motor.
Old Sep 5, 2004 | 10:27 PM
Cuda440's Avatar
Thanks for the info Shotgun. Is it something that can been done pretty quick?
Old Sep 6, 2004 | 08:14 AM
SHOTGUN's Avatar
Shouldn't take long, but it's a close fit, with no room to spare. I had all my plastic off and could get at it easily the two time I did it, wasn't exactly easy, room wise.
Old Sep 6, 2004 | 10:50 AM
KISSSOFDEATH's Avatar
Im gonna have to take mine off soon. I have developed an oil leak in the front diff and at the engine output area. This P650 is starting to require unscheduled maintenance. Lucky for it I dont really mind doing it. Looks like there is an oil seal that will need replacing. I hope it pops out and a new one can be popped in.
Has anyone replaced oil seals from there drive shaft to front diff?
KimSJoh
14
Jul 18, 2015 07:20 PM
JackTheKing
Jul 14, 2015 09:09 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
jettman
Jul 6, 2015 12:16 PM
Mphillips
Jul 2, 2015 07:20 PM
