epi clutch kit good/bad
Old Sep 12, 2004 | 07:31 PM
thebruin's Avatar
Default epi clutch kit good/bad
what should i expect this to do for my yamaha bruin with 26 inch mudlites. cause it lacks the power to spin the wheels in 4 wheel drive if you pin her from a stand still unlike 2 wheel drive.
Old Sep 13, 2004 | 11:17 PM
batmanacw's Avatar
I would get the over size tires kit because it will raise the engagement rpm and get you farther into the power band before it kicks in. You will loose a little top end speed (1or 2mph), but I wouldn't worry about that too much if you are mudding alot. I would do a K&N power kit also. If it does as much as it did with my griz, then you will be very happy. I really like what the EPI clutch kit did for me. I even bought lighter weights so I could get more low end grunt if I decide to go with bigger tires.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
