424 warn
Old Sep 19, 2004 | 10:00 PM
coolguy8769's Avatar
Default 424 warn
i was thinking abou tgetting the 424 warn for my 2004 honda rancher 4x4 es. but i wanted to know if any one was having problems or if they had no problems at all
Old Sep 20, 2004 | 06:55 AM
Grimmsniper's Avatar
Default 424 warn
I've heard of some trouble getting the adjustments right but other than that they have been getting some good reviews. I've got the highlifter un-locker and do not recomend it. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 20, 2004 | 05:15 PM
rcrob's Avatar
Default 424 warn
I have the Warn 424 on my Foreman. I love it and it sure does change the handling of it. Mine was a #%@!^ to install, but it might be easier on the Rancher. Took me about 5 hours total, including adjustments. I ride in 2wd most of the time, and love the fact I can 'shift on the fly' into 4wd when needed.
Rob
Old Sep 21, 2004 | 03:42 PM
LittleBill's Avatar
Default 424 warn
works amazing well on my rancher, just make sure to use the switch from 4 to 2 once and while, i left my in 2 for like a month and it would engage 4x4, had to take apart and clean it, then it was good as new
Old Oct 1, 2004 | 01:40 PM
Daranello75's Avatar
Default 424 warn
Originally posted by: rcrob
I have the Warn 424 on my Foreman. I love it and it sure does change the handling of it. Mine was a #%@!^ to install, but it might be easier on the Rancher. Took me about 5 hours total, including adjustments. I ride in 2wd most of the time, and love the fact I can 'shift on the fly' into 4wd when needed.Rob
do you need to be off power to shift on the fly? if so im thinking of mounting the switch on the right side
Old Oct 1, 2004 | 02:04 PM
rcrob's Avatar
Default 424 warn
You don't have to be 'off' power to shift from 4wd to 2wd and vice versa. In fact, you can go it going down a trail with your hand on the throttle doing 30mph. You just have to make sure that both front wheels and rear wheels are going about the same speed, ie, you don't want your rear wheels spinning in mud (your fronts are not moving or moving slower) then slam it into 4wd. That's a no no.
i would mount it on the left side, imo, because you can still be on the throttle while going in/out 4wd if necessary.
Rob
Jeff Roper
Feb 1, 2022 11:48 AM
toonces
Oct 19, 2015 02:21 AM
panicmanic
Sep 28, 2015 12:59 PM
Erick J. Edler
Sep 20, 2015 05:51 PM
Gtsordo
Jul 22, 2015 01:27 PM
