Prairie 360 update
Old Sep 20, 2004 | 09:32 AM
OleManMoses's Avatar
Default Prairie 360 update
Another good one--went on a poker run yesterday--I tagged a P650 and a Honda Rincon all day---kept right on them--The 360 is more than adequate for woods running if anybody is basing buying one on that perspective---Also had a kid on a stock 360P --no mods---tagging my butt all day--couldnt shake him---at the end of the run I drag raced him in the parking lot both in high range and low range--took him on the holeshot every time and beat him by about 10-15 quad lengths every race.
This kid weighed no more than 150lbs if even that--I weigh 200.
This confirms to me about the carb mods--read this thread--- http://www.thumpertalk.com/forum/sho...25/Main/970019
This is the same carb as the 360
But no matter---in real world riding (lots of mud due to rain) The big bikes couldnt shake me nor could I shake the stock 360.
Love my 360!!!!!!!!!!
Old Sep 20, 2004 | 11:39 AM
another good link to replacing stock carb
http://www.planetklx.com/
Old Sep 20, 2004 | 12:14 PM
Kartmann's Avatar
OMM
I will get with you later this week on the carb. Whats your thoughts on a jet kit and which one? My carb is still stock.
thanks
jeremy
Old Sep 20, 2004 | 12:30 PM
Hey Kartmann---would love to walk you through it---take a look at the links i provided---i am going to try and locate this carb at a reasonable price---If I were going to buy a kit, it would have to be the dyno jet---but dont have any facts on that--consider swapping carbs, or do the needle jet shim and drill out the hole like I did----WANNA RACE??????
Old Sep 20, 2004 | 03:33 PM
Uinthas's Avatar
I really want to try your new found mods, but I'm really hesitant about drilling a hole in my carb! plus you ride at a far different elevation then I. Do you know exactly how drilling this hole improved performance?? What were the spec's on your needle shim??
Old Sep 20, 2004 | 05:12 PM
hey uinthas
not sure what you mean by what are my specs on the needle?? I have shims measuring .060 lifting the needle up if thats what you mean--this mod gave me a lot of ability to rooster tail around turns and a general midrange boost---the drilling of the hole on the slide gave me a lot more pep and quicker throttle response-- almost feels like it could wheelie, but just not enough power. I would bet a small person or kid leaning on back could wheelie it---i think i'm too old--almost pulled my arms outta their sockets last time i tried. Drilling the vacuum hole larger should allow the slide to open quicker---I tried this earlier by shortening the spring on the top of the slide, In order to open it quicker, but for some reason it ran worse. Take a look at the links I provided. These guys have the same carb that we are running. The best way to explain it is if you ever played with a motorcycle carb, the slide is connected to the throttle cable and opens instantly when you nail it. Our slide is lifted by vacuum rushing through the carb---hence the momentary lag when nailing it.
I figured when i did it that if it ran worse, i would JB Weld the hole and redrill it smaller---but I am actually considering drilling it slightly larger.
But then again, why mess with perfection??
let me know
Old Sep 20, 2004 | 07:06 PM
Uinthas's Avatar
where would a guy pick up the .60 shim?? dealer?? I did read your links, & understand more what you say more then what they have to say.. Guess I understand better (not very knowledgeable with carbs) so bascially it gives you a more responsive throttle right?
Old Sep 21, 2004 | 09:32 AM
Hey Uinthas
Right about the throttle response---even if you dont drill the vacuum, you should shim the needle--this has been my best and cheapest mod yet---the shims are just small brass washers that I purchased at Lowes---some of the guys on this site suggesting buying them also at Radio shack--do a search on this site for needle shims--I bought brass ones so i could file them easily to the size i wanted--you would also need a micrometer to measure them---i know it sounds complicated, but once you get in there it is not---the other alternative is the dyno jet kit---seems like there are some good reports on it also--The only thing i know about the dyno kits is for our quads it is only available in a stage 1 kit---this means its for either no mods or slight mods(muffler, air filter)
The dyno kit for the klx 300 dirt bike is a stage 2 kit(for a more modded engine) The stage 2 kit is the one that comes with a drill bit to drill the vacuum hole out. Like I say, i was taking a chance drilling this hole, but figured I would somehow fix it if it didnt work.
Old Sep 21, 2004 | 10:37 AM
kwackermann's Avatar
Do the 360's come in green?
Old Sep 21, 2004 | 10:48 AM
kwackerman
look at my pics!!!
