1990 LT80 won't start, gets gas and coils are good little spark
Old Sep 20, 2004 | 12:47 PM
bluenoser's Avatar
Default 1990 LT80 won't start, gets gas and coils are good little spark
We have a 1990 LT80 i replaced the primary coil and checked the secondary. Both are good. I am getting very little spark and i can get it to fire once in a while when i put gas in the cylinder can someone sugest something?[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Sep 20, 2004 | 01:35 PM
asfasasu3's Avatar
Check the compression. From past exsperiance (sp?) I've found ours needs around 90 lbs to start.
Old Sep 20, 2004 | 01:54 PM
confusedbuyer's Avatar
ditto asfasasu. low compression is often the problem when you've ruled out everything else, and it's easy to check with a compression tester. putting your finger over the hole isn't good enough.
Old Sep 21, 2004 | 10:32 AM
LT80's Avatar
LT80 Expert
Good advice given.
Putting gas in the cylinder points toward compression.
We'll go over the weak spark once you figure out the compression.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
02Chevrolet
Jun 23, 2015 12:12 AM
sticky123
Jun 14, 2015 07:36 AM
hoopduerr
Jun 2, 2015 09:01 AM
MDelby
Oct 1, 1999 08:32 PM
