overheating kawasaki 700 4x4
Old Sep 22, 2004 | 08:40 PM
FASTWAX's Avatar
Default overheating kawasaki 700 4x4
has anybody been having problems with there 650,700,750 overheating
yes we have been running in mud,radiator plugged a little bit
they over heat and you lose your ani-freeze
any one have any solutions
i thought of running that chemical in your radiator thats suppose to run 40 degrees colder
even if the radiator is plugged
has anybody used this chemical
thanks for everyones input
joe
Old Sep 22, 2004 | 09:33 PM
SukiZ400rdr's Avatar
I was checking out a Prairie 700 at the dealer the other day, asked if they
are having any problems, (I know the dealer, he's honest with me) and he
said people are having overheating problems with the Prairies.
He suggested removing the side shields to open it up more. Maybe it
would get more air that way. I thought it resonable since my Vinson
doesnt have those and I have never heard of any overheating with the
Vinson.
Something to try..??
LittleBoy's Avatar
Yes, Evan is a great product. But, since I added my dynatek cdi, I haven't had any heating problem anymore. Better ignition program, delivering all the power the Prairie can give and no agressive timing shut-down that cuts the power on low, mid and top end causing the engine over heat.
Old Sep 22, 2004 | 10:12 PM
FASTWAX's Avatar
thanks i will try that joe
Old Sep 23, 2004 | 12:04 AM
gltco's Avatar
LittleBoy
Were you able to buy your Dyna cdi in Canada or did you have to go south. I am looking for a Canadian supplier.
Old Sep 23, 2004 | 12:56 AM
kodiac1's Avatar
Fastwax.....I have an 02 and have NEVER overheated.I do run water wetter and I am not sure that has helped or not.I never saw the hot light before adding it.I will say they are picky about keeping the radiator clean.I am not saying you did not but you have to REALLY check the whole thing.Two of our guys made this mistake once and both overheated.I use a trouble light from the back side and look from the front to look the entire radiator over.I can ride two full days at Hatfield/McCoy and never have a problem...probably more as long as I start out with a clean radiator.I t happens to all............we had a Rubi overheat for the same reason and a YFZ 450 too. I know the Honda guys are falling all over themselves right now but yes.......we have troubles with the hondas too[img]i/expressions/face-icon-small-wink.gif[/img]
Clean it good and add water wetter or purple ice and all should be well.
02 650 camo
Old Sep 23, 2004 | 08:46 AM
FASTWAX's Avatar
thanks kodiac 1. i will check the rad with trouble light
and i will try the water wetter thanks for your help
joe
Old Sep 29, 2004 | 09:51 PM
Spaceman's Avatar
Got a new 750 and it over heats after every deep mud hole I go through even though there is no indication(getting it looked at). Need to find a creek and wash the rad thoroughly then I can ride again. I want to fabricate a crap guard similar to the polaris's. Just have to learn how to weld. I think the japanese should have built one for me.
Old Sep 29, 2004 | 09:55 PM
skooter525's Avatar
Try some Water Wetter from redline it works well and mixes with antifreeze
wendal
May 9, 2024 09:29 PM
ReconBayou
Oct 16, 2019 02:24 AM
wendal
Oct 31, 2017 03:31 AM
wendal
Sep 15, 2015 01:50 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
