I want a grab bar that WON'T BEND
Old Sep 25, 2004 | 09:10 AM
dondiesel444's Avatar
Default I want a grab bar that WON'T BEND
[img]i/expressions/face-icon-small-mad.gif[/img]
my alum. grab bar is all bent now from doing wheelies. is there any grab bar out there that is super strong? maybe I need a "wheelie bar"!!
I'm thinking of making my own with some thick steel flat bar for the ends and a short tube for the cross-peice, weld it together and bolt it up.
Old Sep 25, 2004 | 09:19 AM
BajaIowa's Avatar
Just don't wheelie onto the grab bar[img]i/expressions/face-icon-small-wink.gif[/img]. Just be careful of making your own too strong. I did that for a friend and he ended up bending his sub frame. I $30 grab bar is a lot cheaper than a new subframe.
Justin
Old Sep 25, 2004 | 04:26 PM
Camds650's Avatar
Put some wheels on the grab bar
Old Sep 25, 2004 | 06:19 PM
OregonDunePatrol's Avatar
They bend for a reason dude ... This prevents the subframe from bending.
Old Sep 25, 2004 | 09:12 PM
MTX's Avatar
MTX
prm grabber :]
Old Sep 25, 2004 | 10:38 PM
CountryJoeGlass's Avatar
I agree, I had a home made one that didn't bend but ripped the tabs off the sub frame. I had to reweld new tabs on the sub frame & the sub frame will never be the same.
Old Sep 26, 2004 | 12:01 AM
bigben's Avatar
Long wheelies are all about the rear brake... and when you miss the brake pedal with your foot you can bend a PRM grab bar.
You could hang a couple of skateboard wheels on you grab bar, but then be ready for comments from your friends about "training wheels."[img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 26, 2004 | 12:44 PM
BajaXRider04's Avatar
I tore out the mounting holes for the grab bar doing wheelies and bent the stock grab bar beyond recognition!
I had to have some new steel welded onto the sub-frame.
I put the PMR desert grab bar from o n d u n e s http://on-dunes.com/Details.cfm?ProdID=120
I then cut some Black well pipe and put it around the grab bar just in case I do a wheelie and it goes back and hits the bar, that way the blacktop rubs on the disposable well pipe and not the aluminum. It works great!
95scramblerruben1033
Sep 23, 2015 06:29 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
black_thunder
Sep 20, 2015 10:21 PM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
PrairieDog126
Sep 12, 2015 05:23 PM
