I want a grab bar that WON'T BEND
[img]i/expressions/face-icon-small-mad.gif[/img]
my alum. grab bar is all bent now from doing wheelies. is there any grab bar out there that is super strong? maybe I need a "wheelie bar"!!
I'm thinking of making my own with some thick steel flat bar for the ends and a short tube for the cross-peice, weld it together and bolt it up.
Just don't wheelie onto the grab bar[img]i/expressions/face-icon-small-wink.gif[/img]. Just be careful of making your own too strong. I did that for a friend and he ended up bending his sub frame. I $30 grab bar is a lot cheaper than a new subframe.
Justin
Justin
They bend for a reason dude ... This prevents the subframe from bending.
Long wheelies are all about the rear brake... and when you miss the brake pedal with your foot you can bend a PRM grab bar.
You could hang a couple of skateboard wheels on you grab bar, but then be ready for comments from your friends about "training wheels."[img]i/expressions/face-icon-small-wink.gif[/img]
I tore out the mounting holes for the grab bar doing wheelies and bent the stock grab bar beyond recognition!
I had to have some new steel welded onto the sub-frame.
I put the PMR desert grab bar from o n d u n e s http://on-dunes.com/Details.cfm?ProdID=120
I then cut some Black well pipe and put it around the grab bar just in case I do a wheelie and it goes back and hits the bar, that way the blacktop rubs on the disposable well pipe and not the aluminum. It works great!
Jersey General
1) Engine problems..
09-13-2015 01:05 PM
