banshee clutch
Old Aug 27, 2000 | 02:43 AM
Vision's Avatar
i just installed a set of barnett clutches in my 99 shee. my ?? is how durable are these compared to stock? i also installed all six springs to insure no slipping.
Old Aug 27, 2000 | 03:10 AM
rottwolf's Avatar
How does it perform? Is it smoother than stock? Under power?
Jason
Old Aug 27, 2000 | 04:07 AM
Vision's Avatar
i just got it in tonight but going to ride tomorrow. but yes it pulls smooth but the heavy clutch pull will take a little more effort.
Old Aug 27, 2000 | 08:55 AM
CapnShiner's Avatar
I recently put a barnett clutch in my banshee.... This weekend, I'm going to take out 3 of the heavy barnet springs, and put 3 of the lighter stock springs back. My clutch hand hurt pretty bad after a day of riding. But my clutch doesn't slip anymore, I hope it still doesn't slip when I change out half the springs.
Old Aug 27, 2000 | 06:08 PM
deathtripper75's Avatar
the three stockers and three barr. is the way to go, just be sure to measure your springs to make sure they are within specs
Old Aug 28, 2000 | 12:21 AM
oppi's Avatar
got a barnett in mine, and my left arm is bigger now. HARD TO PULL. Was checking out those hydraulic clutches for the banshee. What do you guys think about these.
Old Aug 30, 2000 | 12:31 PM
sAyIt_fmf's Avatar
I went with a Barnett clutch and their included heavy duty springs....For me, It felt way too notchy and a bit harder to pull the lever.
I ended up removing 3 of the springs and replacing with the stock ones...It's better, and no slip as of yet.
Old Aug 31, 2000 | 12:30 AM
Jennifer's Avatar
If you think the Barnett clutch is stiff, try a Toomey clutch sometime. Anyway I had a Barnett clutch last time, and went with a EBC Dirt Racer clutch instead this time. I had to replace the clutch basket also though since the cushions were worn. The EBC seems a bit smoother to me. Anyway that's my 2 cents worth for the night.
Old Sep 11, 2000 | 03:39 PM
r42176's Avatar
If you plan on using a Toomey or a Barnett clutch with all of the heavier springs in it then you better make sure you don't rev the bike much with the clutch pulled in. If you do then you will end up welding the ball bearing to the clutch rod. The increase in force on the bearing and the rod will weld it to the rod and may also weld the rod to the actuating arm in the case. Take a look at a mod made by Engine Trix. It replaces the adjustment mechanism so that it uses a flat bearing to ride on similar to the 250R. You'll never weld the bearing to the rod again.
check out this link.
http://www.enginetrix.com/atv-custom...lutchsaver.htm
Jeff
Old Sep 13, 2000 | 04:34 PM
free1steven's Avatar
I use three stock and three heavy duty springs with no problems. Also use an EZ-pull clutch lever. I do not like the Barnett kevlar because they muddy the oil.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
