new 450r problems
Old Oct 8, 2004 | 01:33 PM
bestatc350x's Avatar
Default new 450r problems
ijust bought a 450r about a week ago and ive been riding it and it started stalling once in a while while idleing and when its idling and i floor it it cuts out and then revs up or it just stalls. i noticed a black **** on left side of the bike while ur sitting on it. its below the choke and i heard it was and idle. just wondering wut i should do.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 8, 2004 | 01:59 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
That **** is the idle, so adjust it if you need to. Mine needed idle adjustment after I had ridden it a few times. Mine also had a little bog in the midrange, about 3rd gear and half-throtle. Went away though after I put on a pipe, air filter, etc.
Old Oct 8, 2004 | 02:03 PM
wut type of pipe and air filter did u use? do u like it?
Old Oct 8, 2004 | 02:19 PM
Red Rider
I put on the FMF Factory 4 complete system, UNI foam air filter, vented airbox lid (http://www.ehsracing.com/), HRC cam, and of course a rejet The UNI filter doesn't have that restrictive screen insert that the stock filter has, and flows air very well. I use to have K&N's on all my bikes, but am going back to foam for a greater margin of safety. The EHS airbox lid, probably makes more of a difference than ANYTHING else.
Old Oct 8, 2004 | 03:34 PM
Lancester's Avatar
Does the uni come with something to keep it from collapsing without the inner metal screen you removed?
Old Oct 8, 2004 | 04:36 PM
iceracer65's Avatar
I agree turning up the idle will help...it is a new engine that is still tight... it will need time to loosen up. I broke mine in on a small mx track and almost killed myself in between a small set of doubles...I was singleing them and the quad whould snub for a split second, causing me to lurch forward hitting the gas, then it would bumpstart, sending me off the second one at about half throttle!! Never had a prob after it was broke in doing the same thing.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
