blaster exhaust spring
Old Oct 9, 2004 | 12:56 AM
Rem's Avatar
Rem
Default blaster exhaust spring
i bought a used DG pipe and silencer for my blaster, the dg pipe i bought didnt come with a spring. my first question is: are exhaust springs usually universal? my second is: where do i put the spring that connects to the cylinder? i cannot find any spring hole or anything of the matter. also, do i use the crunch gasket thing with the DG pipe too?
thanks for help in advance , rem
Old Oct 9, 2004 | 09:55 PM
soon2bBlaster's Avatar
most pipes will come with a new flange but some dont. fmf makes them on rocky mountain im not sure if it will fit though. if you are using the stock flange you can make a bracket with two holes one hole is used for the spring and the other one will go behind the nut on the cylender. thats what my friend did with his fmf anyway
Old Oct 10, 2004 | 12:57 AM
Blaster7878's Avatar
Old Oct 10, 2004 | 01:20 AM
Rem's Avatar
Rem
how do i use the exhaust flange on the DG pipe, i bought it used and the jack*** didnt show that the hanger was broken off, the silencer has a HUGE dent, and there was no spring or flange. can i cut the one off my stock pipe and weld it back together on the DG , i will weld a new hanger on it, so should i just buy a spring? thanks
Valder
Nov 28, 2020 07:38 AM
Divergent12
Dec 30, 2017 08:33 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
antiguogrumete
Sep 5, 2015 03:41 AM
