blaster exhaust spring
i bought a used DG pipe and silencer for my blaster, the dg pipe i bought didnt come with a spring. my first question is: are exhaust springs usually universal? my second is: where do i put the spring that connects to the cylinder? i cannot find any spring hole or anything of the matter. also, do i use the crunch gasket thing with the DG pipe too?
thanks for help in advance , rem
most pipes will come with a new flange but some dont. fmf makes them on rocky mountain im not sure if it will fit though. if you are using the stock flange you can make a bracket with two holes one hole is used for the spring and the other one will go behind the nut on the cylender. thats what my friend did with his fmf anyway
how do i use the exhaust flange on the DG pipe, i bought it used and the jack*** didnt show that the hanger was broken off, the silencer has a HUGE dent, and there was no spring or flange. can i cut the one off my stock pipe and weld it back together on the DG , i will weld a new hanger on it, so should i just buy a spring? thanks
fordfaithful21
Dec 7, 2015 05:52 PM
