p650 clutch question
Old Oct 18, 2004 | 05:16 PM
Xrxman's Avatar
Default p650 clutch question
I have a lot of play between the bushing an the shaft on the primary clutch, just wondering how much is normal or do i need to replace the bushing? Any input will be appreciated
Old Oct 19, 2004 | 08:08 AM
Xrxman's Avatar
Can anyone answer this question???
Old Oct 19, 2004 | 10:42 AM
KISSSOFDEATH's Avatar
If you measure the inside diameter of the bushing the service limit is 28.19mm or 1.110".
Standard is 28.055~28.155mm or 1.1045~1.1085"
Old Oct 19, 2004 | 10:34 PM
Xrxman's Avatar
Thanks KOD this tells exactly what i need
Old Oct 20, 2004 | 07:37 AM
You are welcome.
Old Oct 21, 2004 | 05:20 PM
NovaKaw650's Avatar
I finally got the new bushings and seals from Kawi for my secondary clutch. I'll try to put them in the next week or two and then post how the job went.
Old Oct 21, 2004 | 11:01 PM
crazy22's Avatar
kod you sound like you know this bike very well i have a ques . i have 03 650 and it not as fast as it was the 3 dealer i have brought to are at a lost my top speed was 62 and now at 51 any idears would be help full
Old Oct 22, 2004 | 02:00 AM
tuffEnuf's Avatar
Crazy
Checked your belt deflection & Belt for Proper Specs? Also ensurte your jetting is on par & a clean airfilter or not too much oil in your air filter and ensure your choke plungers springs are not weak.
Happyy Trails
Old Oct 23, 2004 | 03:36 PM
crazy22's Avatar
that was done
ghost civic
Jan 15, 2020 07:43 AM
4464
Aug 21, 2015 01:46 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
