high lifter icm?
Old Oct 19, 2004 | 10:51 PM
700pteamgreen's Avatar
Default high lifter icm?
whats the word on the high lifter icm for the p700? or how does it compare to the dg3 or dyna? the way it sounds is that the dyna cdi has some problems. any info would be great!!!!!! pete
Old Oct 20, 2004 | 01:50 AM
Dynascott's Avatar
Curious, what problems are you talking about?
Scott
Old Oct 20, 2004 | 06:10 AM
killzoneq2's Avatar
DANA OVERIDES YOUR REVERSE OVERIDE BUTTON SO YOU DO NOT HAVE TO USE IT, HIGH LIFTER DOES NOT MESS WITH THIS OPTION. THE ONLY DIFF I HAVE READ ABOUT IS WHAT I JUST MENTIONED AND THE PRICE. I HAVE THE HL WITH 27" ON MY BRUTE AND IT WILL FLIP YOU OVER WITH POWER.. I WOULD NOT HAVE ANY OTHER ON MY KAWASAKI.
Old Nov 20, 2004 | 10:34 PM
jawyatt's Avatar
I just put a new HL ICM on my bf and it did nothing. I soldered it like it said to but still nothing. So i took it off and cant connect the pink wire back together. Does anyone know what the wire is for and if i really need it. Any suggestions on what i can do to make it work.
Old Nov 20, 2004 | 10:46 PM
killzoneq2's Avatar
Give me your email and I will send you pics, You should notice a Huge difference
Old Nov 20, 2004 | 10:51 PM
700Hemi's Avatar
is the highlifter icm the same for the prairie and BF??
Old Nov 20, 2004 | 10:53 PM
jawyatt's Avatar
Here is my email EMM576@CS.com
Old Nov 20, 2004 | 10:57 PM
jawyatt's Avatar
Yes the ICM is the same one for the 650.
Old Nov 21, 2004 | 10:52 AM
CAridgerunner's Avatar
They are all going to be the same because they all use/share the same timing
5 deg. BTDC @ 1,100 rpm
28 deg BTDC @ 5,000 rpm
The BF750 differs slightly since it is set at 5 deg BTDC @ 1,150 Rpm, no sure if that small difference is why some are having the miss at low rpm or not
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
fredrikrosen
Sep 28, 2015 09:58 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
