No reverse
Old Nov 1, 2004 | 11:17 PM
mschreck's Avatar
Default No reverse
My dads 00 Sportsman 500 has some reverse problems. He shifts into reverse, the light doesn't come on in his pod, but he does drive in reverse. His rev limiter doesn't kick in so he can go full boar in reverse without using his override button, but he also doesn't have 4 wheel drive in reverse. So he gets stuck when he needs the 4 wheel reverse. Since the machine doesn't recognize that he is in reverse it won't do what it should do. There are two switches that the machine uses to tell what gear he is in. Should I replace one of these switches? Which one? Or should I start somewhere else? Please help!!!
Old Nov 1, 2004 | 11:40 PM
SPORTSMAN70003's Avatar
Default No reverse
I think I read in another post that there is a switch that has to make contact when you pull it in reverse it might not be making connection or went bad.
Old Nov 2, 2004 | 11:54 AM
mschreck's Avatar
Default No reverse
But do you know which switch? There looks like there are two of them, one with 4 wires and another with 3 wires. Do you happen to remember where you read the other post?
Old Nov 2, 2004 | 01:56 PM
Default No reverse
I think this is were I read it its close to the same problem you have.
http://atvquadsquad.com/eve/ubb.x?a=...54&m=264102249
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
poutlaw525
Sep 9, 2015 03:19 AM
