neutral and oil light not working ,help
Old Nov 6, 2004 | 02:51 PM
1prokiwi's Avatar
Default neutral and oil light not working ,help
What would cause both of thse to not work ???? I have checked the two fueses under the seat , nothing ...
any ideas ??
Old Nov 6, 2004 | 06:00 PM
Eaglecollector's Avatar
You didn't say...so i have to ask. Have you checked to see if both lamps good? They could both be bad. If they are then I would say the lead from the key switch to the lamps has a break in it or more unlikly the ground wire from each lamp is no good. In the red lamps case it goes through either of two switches to ground. One being oil presure switch and the other being the water temp switch. On the nutural lamp it goes through the switch just under the oil filter area. It's the wire that goes along side of the oil filter cover. Make sure the small philips screw is still connecting that wire to the side case.
Old Nov 6, 2004 | 09:13 PM
1prokiwi's Avatar
Thanks Eaglecollector , i hadn't thought to check both bulbs. Have tried unsuccessfully to get the bulbs out and cant move them. Do u push in on the little tabs on the side of the housing??
might have to take it in to shop i think !
Old Nov 6, 2004 | 09:22 PM
Yes that is exactly how you do it. Unplug the wires and push in on the tabs as you push the bulbs up and out. I usually just get replacement ones from the local outo parts store. 1.99 verses the 10 bucks that bomb wants for theirs[img]i/expressions/face-icon-small-shocked.gif[/img]
hugemoth
Jul 20, 2020 03:28 AM
jayking232003
Dec 4, 2019 09:38 AM
tweeder
Jul 5, 2015 01:57 PM
Mphillips
Jul 2, 2015 07:20 PM
bikedad3
Jul 2, 2015 02:15 AM
