P 700 Engine brake
Old Nov 7, 2004 | 08:04 PM
grownmancrying's Avatar
Default P 700 Engine brake
I know this has been gone over before and I searched the forum but did not find my particular problem.
My 04 P 700 4wd and 2wd light started blinking at 1 second intervals again. Now my prairie engine brake just whines the whole time the machine is running. When put in gear the machine will take off on its own at idle, either in forward or reverse. Do I need to just buy a new actuator or clean the engine brake?
The brake does not reset after shutting the key off.
Thanks
Steve
Old Nov 7, 2004 | 10:18 PM
kawakasi's Avatar
Hey neighbor
Sounds like the actuator motor isnt working
I took mine off the other day...wanna borrow it?
Dave
Old Nov 8, 2004 | 11:50 AM
kwackermann's Avatar
Hey kawakasi, can you run around without the actuator motor without everything else going awol?
Old Nov 8, 2004 | 01:16 PM
kawakasi's Avatar
Yep i removed mine.....4WD/2WD flashes
newbeatle posted a fix for that a while back
Kasi
Old Nov 8, 2004 | 03:01 PM
... hmmm, irks the H&ll outta me with all these actuators and motors all over and things not resetting. I think I'll settle on a Bayou 300 4x4
Old Nov 8, 2004 | 03:20 PM
Hello Dave,
Does your machine want to move on idle without the actuator?
Been a while since I heard from you . How are things going?
Steve
Old Nov 8, 2004 | 07:24 PM
kawakasi's Avatar
Steve
It runs great without the actuator...sqeals a bit @ an idle, but thats from the 700 belt and no shims
Runs even better since I packed my pipe....I forgot how much low end grunt back-pressure provides
Have you checked your fuse? Just a thought
Old Nov 8, 2004 | 11:06 PM
Do you have to almost force it into gear??
Gotta get you guys down here to ride this winter when the river ices over. Sounds kind of dangerous but is a lot of fun if you are careful.
Old Nov 9, 2004 | 12:53 AM
kawakasi's Avatar
It goes into gear pretty good....belt aint that tight
Yes I would like to do a little river cruisin...Missouri is a lot bigger than the Sioux
Old Nov 9, 2004 | 11:21 AM
.. how do you be careful on a frozen river. when you go thu you go thru...
