Talked tot he wife about mods this winter and-
Old Nov 25, 2004 | 03:19 PM
jackass650's Avatar
Default Talked tot he wife about mods this winter and-
she said i could rip it all apart take off the jugg make sure the piston and rings are good if not replace if i need a valve job get it done i have to keep the same cams and valves stock ones, then i can have my buddy here in mn powdercoat my frame what ever color i want an then i am going for the orange and black baja plastic, then as i put it togethere checking all my bearings and bushings on everything, what would i need to do to get it ready for cold weather storage? it is not uncommon for it to get down to minus 30' f here in red wing, do i need to drain my antifreeze or make sure it ok down that far and will the oil be ok that cold thanks fellers again
Old Nov 25, 2004 | 05:36 PM
moldycheese's Avatar
if your running 50% antifreeze and 50% water you'll be alright for at least -40 and if your not going to ride it in the winter your oil is ok to, but i would change it now so you dont have to do it before you go riding again in the spring
Old Nov 25, 2004 | 09:13 PM
jackass650's Avatar
ok thanks moldy
Old Nov 25, 2004 | 10:15 PM
busmechanic's Avatar
I would change the antifreze too. as cold as it gets there. plus its due every 2 years acording to the shop manual.
Old Nov 26, 2004 | 01:19 AM
mystereid's Avatar
It's official, I've been duning for over 30 years.
Jackass650, that's too bad about your cylinder, I can tell without looking that it requires boring[img]i/expressions/face-icon-small-happy.gif[/img] Oh, and that flat cam lobe!
Old Nov 26, 2004 | 01:44 AM
jackass650's Avatar
whats wrong with my cylinder? i have 210 lbs of compression i just wanna go through everything this winter so i am fresh next summer
Old Nov 26, 2004 | 01:52 AM
mystereid's Avatar
Yeah, 230, that's a shame. I'm sure a 730 kit would fix that problem[img]i/expressions/face-icon-small-wink.gif[/img]
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Johnny Mac
Aug 15, 2019 03:13 PM
r1pilot83
Sep 27, 2015 07:38 PM
2many2ride
Sep 27, 2015 04:35 AM
Sep 23, 2015 06:23 AM
