LTE for the DS650? Check this out
I've heard a mixed bag on the LTE's for various quads, some like them some don't. There's some Dyno charts on the sweetquads webpage I was checking out. They show the DS losing power on top end....something doesn't seem right to me....losing power on top with these? Can anybody vouch for this?
LTE on DS 650
LTE on DS 650
Look Predfan If your going to post a Dyno chart you had better Post ALL the relevant info or your just talkin BS!! Hell at least lie about what the carb and settings were used, that chart you show us doesnt show us jack! If it showed 90 hp I would still say BS Whats the compression , is it stock bore and stroke ETC.... give it up dude!!
Look further and you'll see there are other dyno's too. Take alook at the raptor Dyno sheet. Boy that stock raptor reading looks suspicous too, wandering all over the place. My point is not to get people like you, PROZACK to get all ruffled, just find out why this posted information FROM ONE OF OUR SPONSORS ON HERE shows this Dyno.....GET IT NOW, PROZACK?
And yes, it looks like it is very possbile that the dyno could be an optical illusion as mentioned, but usually, you don't see the curves hitting each other in the mid-to upper RPM's.
Im simply saying that there are other charts from LTE that don't exacltly match what that one shows. So, there is something different on the mods or on the dyno or some other conditions that cause a variance from the sheets I have from LTE. Other people can obtain them the same way I did - by asking LTE for them. The "other place" I mentioned (which got deleted) is LTE. Since they did the dyno, maybe someone should just call Randy and ask. I am about 85% sure that both of the pipes tested in this dyno above meet at 6,000 rpm - and that the LTE moves up instead of down as previously speculated. That would explain why the peak horsepower is so close to the stock HP already published by so many people already. This is one of the problems resulting from someone trying to speculate on an LTE dyno, when the tester isn't there to help explain the results. My experience with LTE pipes is that they make power on the top end, not take away when compared to stock.
