bad spark
Old Dec 24, 2004 | 04:56 PM
87LT230's Avatar
Default bad spark
I have a rm250 and it have bad spark it is not a nice blue spark it is like purple and it will not run.. Is that the coil or what do you guy's think it is?? thank's
Old Dec 25, 2004 | 10:09 AM
VelociRaptor350's Avatar
Default bad spark
My friend had the same problems with his dirtbike, check the output of the stator, its supposed to be around 8 volts. After that check to see if you have power coiming out of the module, up by the forks.
Old Dec 25, 2004 | 02:52 PM
hondabuster's Avatar
Default bad spark
Have you tried a new spark plug, and get the same results?
Hows the compression?
Old Dec 25, 2004 | 11:02 PM
87LT230's Avatar
Default bad spark
yea I did tried a new plug and it have good compression.
Old Dec 26, 2004 | 08:20 AM
Default bad spark
Did you get the bike wet? My friend's bike turned out to be the stator, when we took the cover off there was water in there from a blown stator gasket. We replaced that and the coil and it ran like a champ.
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
