New 800 shifting
Old Dec 25, 2004 | 04:23 PM
500DUSE's Avatar
Default New 800 shifting
Dealer is closed and I'm haveing a hell of a time shifting when bike is running.
When its off it shifts fine
Anyone have a clue?
Old Dec 25, 2004 | 04:58 PM
Polaridoo's Avatar
If, for some reason, it's idling too high, that could cause it. Also, if the clutches needed aligning, that could cause it.
Old Dec 25, 2004 | 05:36 PM
500DUSE's Avatar
idiling is at 1200,upper end of the spec's.
cant be adjusted that I know of.
Tried adjusting the throttle ,but that dident work.
I'll give the dealer a call monday about clutch Alinement
Old Dec 25, 2004 | 10:01 PM
elkbow's Avatar
how old is your machine, how many miles....it takes a few miles to get the unit to shift easier...i.e. break-in....my '05 700 EFI was stiff as hell until I road it for awhile and did some shifting...
Old Dec 26, 2004 | 06:39 AM
500DUSE's Avatar
Brand spanking new.
Was yours so stiff you had to fight it to get it in gear?
I'm gonna try to get a ride in today .
Old Dec 26, 2004 | 08:18 AM
Polaridoo's Avatar
If you can shift between the gears just fine with the engine off but it gets difficult to do the same thing with the engine running, I would say you have a too high idle issue or clutch alignment issue.
Old Dec 26, 2004 | 08:43 AM
mtpockets's Avatar
on my old '04 700EFI i initially had a similar hard shifting issue. i brought it back to the dealer, they said they lubed shifter 'stuff' and when i got it back, it shifted PERFECTLY.
whatever they did, it did the trick. very happy after that!
(other possibilities have already been listed in above posts)
let us know what you or dealer find.
[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 26, 2004 | 09:56 AM
elkbow's Avatar
Originally posted by: 500DUSE
Brand spanking new.
when i first got it, I had to really push to get it in gear, it seemed to loosen up pretty quickly....if riding it and doing some shifting doesn't loosen it up, then I would take it to the dealer and see what is wrong...
Old Dec 26, 2004 | 01:46 PM
500DUSE's Avatar
took it for a little run and it loosened right up[img]i/expressions/face-icon-small-smile.gif[/img]
thanks all
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
