2000 polaris scrabler 4x4 problems
Old Dec 31, 2004 | 12:41 PM
500scrambler4x4's Avatar
Default 2000 polaris scrabler 4x4 problems
i have a 2000 polaris scrambler 500 4x4 that is completely stock. maybe someone can help me figure this out. last week i was sliding around in 2wd in the snow and the 4x4 right hub locked in. i didnt know what to do so i just put in 4x4 and left it there. the next day i was riding it in 2wd again the same hug locked in when i was at a very high rear wheel spin and is shattered a u-joint and bent the yoke. i got the new parts and i dont want to put it together until i find out whats wrong. can somebody please help me with this problem.
Old Dec 31, 2004 | 01:44 PM
legenderacer88's Avatar
I have a 2001 scrambler 500, I last month i had the same problem then you. You have to change the spring and the plate with 3 pins in your right hub. After that everything will be fine.
Old Dec 31, 2004 | 02:42 PM
Is that it because i have been told that it could be low fluid too. Because when i took it apart there was no fluid in it. That was just the way i got it. When i took it apart all the springs and pins were in perfect shape.
Old Dec 31, 2004 | 03:36 PM
BigBadScrambler's Avatar
If you had NO fluid in it, then that right there could have caused the hub to engage
Old Dec 31, 2004 | 04:00 PM
Polaris500HO4x4's Avatar
yeah that was your problem im almost 100% positive after hearing that u had no fluid in it... make sure you have the right ammount of fluid in it i think they take 4 Oz not that much and its real cheap also... sence this problem youve had i would check the fluid at least once a week
Old Dec 31, 2004 | 06:05 PM
Does anybody know if the u-joint that is open and the u-joint that is in the boot on the axle are the same size or is different, beause i ordered my parts and got them and the u-joint is to big for the yoke coming of the differential. And does anybody know were somebody sells really cheap u-joints. If somebody knows please tell me becuase i cant wait any longer to ride this beast![img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 31, 2004 | 06:27 PM
i dont think there is a u joint in the boot i think thats a CV joint
Old Dec 31, 2004 | 06:47 PM
it is thank you for all your help.
Old Dec 31, 2004 | 07:29 PM
Polaris uses industry standard parts for their bearing and u-joints. If you take the old one down to an auto parts store, they should be able to match it up.
green giant
Jul 13, 2017 12:07 PM
polaris scrambler00
Jun 20, 2015 08:49 AM
wbfjim
Jun 8, 2015 06:20 PM
Peeps
Mar 24, 2000 12:27 AM
