HELP FAST!!!!
Old Jan 5, 2005 | 06:09 PM
Ricke's Avatar
Default HELP FAST!!!!
I just got a new chain for my sport 400 and it was to long so i cut in down to match the old one same links and everything and now its to small. but it has the same amount of links as my old one whatz going on???
Old Jan 5, 2005 | 06:51 PM
mudmaster250's Avatar
the old one stretched. did u cut it to the same number of links or length? are u sure u have the axle carrier adjusted right? just a few ideas. im not really sure though
Old Jan 5, 2005 | 06:58 PM
Ricke's Avatar
ok when i layed it out next to the old one the old one was longer, so i compressed it, so now am i f-ed er what, the links are the same number, i counted!!! how
Old Jan 5, 2005 | 07:23 PM
ftwflh's Avatar
DONT PANIC so you cut the chain too short.Roll the carrier to the point where the chain is closest.Add the piece you cut off to the master link.If you have an older quad with non concentric setup compress the shock if it is concentric let it set level.See how much you need to add and cut off the rest.Get you a second master link and you are good to go.Now remember to double check before cutting next time.BEEN THERE DONE THAT[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 5, 2005 | 08:41 PM
Ricke's Avatar
ok i got another link thanx, but the back bolts that you loosen up to tighten the chain, i was tightening them back up but i got it tight but the bolt still moves arond but i cant tighten it ne more???
Old Jan 5, 2005 | 09:21 PM
CED's Avatar
CED
Sounds like your threads are gone,you will need a new bolt.Man you are having a bad day,don't touch anything else till tommorow.Just joking.
Old Jan 5, 2005 | 11:28 PM
ftwflh's Avatar
Try putting a large washer under the nut
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
Irishman301
Sep 23, 2015 01:47 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
01ssls1
Sep 22, 2015 06:50 AM
