shifting problem - clunking
Old Jan 7, 2005 | 10:33 PM
SHAWNSCAT's Avatar
Default shifting problem - clunking
Sometimes I have clunk when shifting between first and second gear. Its a 04 Artic Cat 400 Manual with 200 Miles on it. It seems like its I rev and when tring to shift to second it stuck in neutral for a second or two before it shifts in to second with a clunk(bang) type noise. This only occures once in a blue moon. This happened when trying to go through mud one time. I was making it through fine in first gear and then I went to shift to second and it seemed like it went to neautral then all a sudden bang it went into second with a clunk and jerk then it seems to work fine. Like I said this doesn't really happen much. I've actually only noticed it 5 times in 200 miles. So I want to know what you guys think this problem could be. I have been reading this forum for awhile and always trust what you guys comes up with. I thought it maybe the wet clutch oil. I use regular ac oill. Do you think it needs serviceing or the clutch adjusted. Or is this something more simple? Thanks for your time in advance.
Old Jan 7, 2005 | 10:43 PM
Bear4570's Avatar
If you ride the shift lever with your heel you will be in a neutral until you get off the lever. Every once in awhile I do the same thing on my '05 400 manual when I don't pay attention to what I'm doing. This usually happens when several things are going on and I have to divide my attention between them, you know when it all turns to $h!t.
Old Jan 7, 2005 | 10:47 PM
SHAWNSCAT's Avatar
Ya I thought of that but that doesn't seem to be the problem cuz I've been riding awhile and watch out for doing what you described. Any other suggestions?
Thanks for the input Bear4570. I see you on here all the time and trust what you have to say.
Old Jan 7, 2005 | 10:55 PM
SHAWNSCAT's Avatar
you know the more i think of it you could be right .. i just hope its me and not the bike
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
brad wheeler
Jul 13, 2015 11:19 PM
coolguy420
Jul 10, 2015 01:17 AM
sara durrant
Jul 6, 2015 05:32 PM
