AWD NOT WORKING
Old Jan 15, 2005 | 06:24 PM
00SCRAMBLER5004X4's Avatar
Default AWD NOT WORKING
IM SURE THIS HAS BEEN POSTED BEFORE BUT I COULDNT FIND IT. I HAVE A 2000 SCRAMBLER 500 4X4 AND THE OTHER DAY WE HAD SNOW SO I WENT TO FLIP THE SWITCH TO 4X AND NOTHING HAPPENED. ANY ADVICE WOULD BE APPRECIATED. THANKS
Old Jan 15, 2005 | 07:55 PM
brainiac213's Avatar
does the light turn on when you turn the switch on. if it doesnt then pull the front hood off and check all of your connections. if the light does come on do the same thing. just tryin to help.
Old Jan 16, 2005 | 09:05 PM
thanks brainiac i will check that out. i did not notice it at first.
Old Jan 16, 2005 | 09:07 PM
Polaris500HO4x4's Avatar
as everyone knows check your hub fluid... the hubs take very little fluid and if u run dry it wont engage for you... check those and refill or change the fluids lets us know
Old Jan 16, 2005 | 09:08 PM
o and by the way welcome to the forums... this is a great place everyone is willing to give a helping hand [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jan 25, 2005 | 08:53 PM
i checked hubs, wiring, and switch and all seemed fine. then i started the quad and revved it up and the lite started to go on then off. long story short, the battery was dead!!! charged it up and the awd is working. anybody ever have this happen???
Old Jan 25, 2005 | 08:56 PM
stevebogusta's Avatar
Hey I will check that on my machine. But that seems odd
Old Feb 5, 2014 | 10:54 AM
mike beck's Avatar
If it is b cuzhubs low on oil..would light still come on??my light will not come on I checked all connection they seem fine???
Old Feb 5, 2014 | 12:50 PM
If you've jacked the machine up,awd on and in gear and the front tires don't turn,it's probably the switch in the gear selector box not allowing the awd button to light up which completes the circuit to the front wheel drive.Bad design that was later changed to the transmission. While in gear push the gear shift lever a little harder and see if the awd lights up,plus check low range. Usually does better in low as it's not used as much.Plus if you really haven't checked the front wheel drive,could be as simple as a burnt out bulb. Item #7 on the bulb. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Item #14 on the high$ switch. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Most of the time it's worn out shift box components(shifter,linkage slides,etc) that don't allow the switch plunger to contact the shift lever. Some posters have jumped the gray wire from the shift box to the red or red/white section on the circuit board to gain full time awd if it's the shifter switch,but that's up to you.Not crazy about that idea! Plus do a fluid change if you haven't already done so. Polaris Demand Drive Plus fluid only.
Old Feb 5, 2014 | 01:18 PM
mike beck's Avatar
How can u tell if bulb is bad it is silver
