recoil help
Old Jan 16, 2005 | 07:02 PM
ishmael's Avatar
Default recoil help
the recoil in my trike is messed up the rope wont go all the way in what should i do ??
thanks
Old Jan 16, 2005 | 07:54 PM
MY86ATC350X's Avatar
Default recoil help
remove the recoil and clean it up some wd40 should work if its stuck.
Old Jan 16, 2005 | 08:21 PM
110Wearwolf's Avatar
Default recoil help
take it all apart and wrap teh rope around one more time to get more spring in it then it will go in all the way
Old Jan 16, 2005 | 08:25 PM
ishmael's Avatar
Default recoil help
ok what happens is i put it back together and the rope is in all the way and i start it and it doesnt go back in all the way about half wont go back in
Old Jan 16, 2005 | 11:57 PM
MainLine's Avatar
Default recoil help
Hello,
I have rebuilt / reround several of them... the first time i almost threw it through the wall trying to wind the spring back up... but it gets easier with each try... i even rebuilt one in the feild in about 15 mins. when i used nylon rope and it melted... make usre you use a heat resistent rope like cotton. some reccomend a coated steel cable, i tried this as well but the coating got too hot and melted. it would work well if you could find a heat resistent steel coated cable? the service manual is confusing to say the least. but there are a few good tips in it... i used bailing wire to make the little alighnment wire... a plieable wire makes it easier to pull out once you have aligned the spring. also, MAKE SURE YOU WEAR GLOVES AND SAFTEY GOGGLES! that spring can really do some damage if it flies out! it is a little frustrating but i was able to do it by following the instructions in the manual (availble on ebay - try seller wyomingben) and gets easier each time.
good luck,
biGjOhn
Old Jan 18, 2005 | 08:14 PM
ishmael's Avatar
Default recoil help
yea that really didnt help me mainlane
Old Jan 20, 2005 | 03:12 PM
barrister1's Avatar
Default recoil help
Ishmael-
Is it taking some of the rope back in, but not all of it? If so, here's what you need to do. Take the recoil off the trike. Remove the pulley and wind the rope around it until it is near full. Leave the end of the rope that the handle will go on empty and sticking out with plenty of extra. When you put the pulley back into the case, turn it slightly counter-clockwise so as to "engage" the recoil spring. Now put the whole thing back on the trike, but leave a bunch of extra rope hanging out the hole. Do not tie the handle on yet! Pull all of the rope out and let it wind back in as far as it will go. Do this once or twice just to get any slack out, then let it wind back in again. Where ever it stops winding back in, mark the rope at that spot, and tie your handle on just below the mark. That way it will keep the handle snugged up nicely against the recoil case. Hope this helps.
Dammar
Apr 20, 2016 06:03 AM
WesTech
11
Aug 11, 2015 07:55 AM
Desimation2k8
Jul 17, 2015 12:37 AM
fullthrottle
Jul 10, 2001 07:52 AM
