How to clean an O-ring chain without breaking o-rings???
Old Sep 15, 2000 | 12:02 PM
c400ex1234's Avatar
I have been using PJI STICKY formula (the wrong stuff) on my chain, and i recently purchased the BLUE LABEL PJI. I have already degreased the sprockets, and swing-arm, but how do i degrease the chain without deteriorating the o-rings? I can't use engine de-greaser.
what about PURPLE POWER? will this harm the o-rings (dosen't say anything on the bottle about plastic and rubber)
ALso how do you remove the chain on a 400ex? Is there a master link? or do i have to grind down a pin, and hammer it out?
PS: i don't have a chain breaker.
Old Sep 15, 2000 | 12:25 PM
BigCrashChris's Avatar
There is a master link as far as I know. I also used the Sticky crap, now my swing arm is all blue and gooey. I'll not be using that on my new Raptor.
I would probably soak the chain in a degreaser over night, and use a tire brush to clean it up in the morning.
Old Sep 15, 2000 | 01:08 PM
dune400ex's Avatar
Kerosene and a plastic toilet brush. Looks like new and won't hurt O-rings. I don't think I'd soak it though, might wash out the oil inside the chain.
Old Sep 15, 2000 | 02:03 PM
Skunky's Avatar
First the sticky ****(opps) stuff... You guys are putting to much on if it is flinging off. 2nd the chain... The is no master link. You will have to shorten the chain via the chain adjuster to get it off (or grind it,etc)... 3rd Cleaning... Y take off the chain? Get a chain scrupper kit it comes with the cleaner that is ok for o-rings and the scrubber mounts on the chain..
Old Sep 15, 2000 | 02:10 PM
c400ex1234's Avatar
thanks guys..
what i did (got a large bowl of kerosene, worked my way all through the chain scrubbing, and all. Then after i was done, i waited for the kerosene to dry. Then i wiped off some dry cruty stuff off the chain.
Result: Looks like new, well kinda.
next time i am using sludge away and a cleaner kit.
Old Sep 15, 2000 | 02:19 PM
hot_shoe_cv's Avatar
The Yamaha manual advises kerosene to clean o-ring chains. Since 0-rings aren't bike specific, I would think that info would apply to any machine. If you'd use Chain Wax by Maxima you would not have the problem in the future. As soon as the carrier evaporates, all that remains on the chain is a waxy, non sticky lube which doesn't attract dust, even here in Az.
Old Sep 15, 2000 | 10:57 PM
Fixxxer78's Avatar
I use a toothbrush.
Old Sep 16, 2000 | 12:41 AM
Jeffksf's Avatar
I think o-ring chain is overrated. More expensive, you never know if your lubing or cleaning it right, my 6 month old o-ring chain has stiff links in it already. Save your money and by non o-ring chain and lube it with whatever you want. Less drag with no o-rings
Old Sep 16, 2000 | 01:07 PM
c400ex1234's Avatar
did i say i bought the o-ring chain??? no...
skinnyr6
Aug 25, 2023 02:18 AM
greg74
Sep 10, 2019 03:03 PM
95wolv
Jul 17, 2015 08:13 PM
tricky123
Jul 12, 2015 05:51 AM
Unzzy66
Jul 11, 2015 10:01 PM
