Problem with 250
Old Jan 22, 2005 | 08:08 PM
MarylandHunter's Avatar
Default Problem with 250
I noticed a fluid, appears to be a gas/oil mix, dripping from the duckbill tube coming from the air filter box. For those of you familiar with this engine, it is the tube that goes all the way up to the front of the bike, and back again, and drains just above the skid plate on the right side of the engine. It seems as though the engine is a little bogged down, too. I'm going to call my dealer, but they won't be opened until Tuesday. Any ideas in the meantime?
Charlie
Old Jan 22, 2005 | 08:23 PM
ArcticBrat's Avatar
How much oil in the bike? you may have over filled.I would check that first.Also if you had the bike on its side or rolled over you might have drained some oil in the airbox.
Old Jan 22, 2005 | 08:42 PM
Thanks for the reply, ArcticBrat. I haven't added any oil since buying it, (it's brand new), and it didn't do it up until today. It hasn't been on it's side or even on uneven ground for that matter.
Charlie
Old Jan 22, 2005 | 09:14 PM
ArcticBrat's Avatar
Charlie
Have you checked the oil? Maybe the dealer over filled it. Just a thought
Old Jan 22, 2005 | 09:25 PM
Bear4570's Avatar
That drain is the airbox drain. Only 4 things can drain thru it. Air (not a problem), Gas (flooding carb or blow back thru carb) Oil ( from the crankcase) and water (either condensation or outside water from rain , etc.)
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
