Oil change for Eton Viper???
Old Jan 23, 2005 | 12:46 PM
CRFNick's Avatar
Default Oil change for Eton Viper???
Well the owners manual sux ballz. Anyways how do you do it???
Old Jan 24, 2005 | 10:29 PM
spike99's Avatar
We have a Pred-90 that also has a CVT Tranny. To change the CVT Oil on our unit, I remove the tranny plug at the bottom, let the oil oil drain out, then squirt 7 ozs of Blue Polaris Gear Oil into the top plug of the tranny. Since the top hole is so small, using a small funnel is a "pain in the tail". Tonight, I purchase a little fluid injector tool. Looks like it might work better. For a visual, surf: - Press Here -
To check its oil level, I then check against its sight glass. For details, surf: - Press Here -
For your E-Ton unit, I'm sure its a simular process. However, I did read once that its Oil Injection tank bracket might be in the way. If I remember correctly, E-Ton uses a dip stick. Hopefully, an E-Ton owner can provide more details for you.
Hope this helps....
Old Jan 25, 2005 | 08:07 PM
chubbysdad's Avatar
My sons eton 50 is that way. I just removed the oil injection tank bracket and it just had a little **** that unscrewed not a dipstick and used the container that the gear oil came in cause it had a small neck.
Old Jan 26, 2005 | 10:58 AM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Guess you already answered my PM, Spike! Thanks for the info! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 26, 2005 | 10:07 PM
Vavoom's Avatar
I just changed the oil in my kids Eton Viper 50. Drain the oil out of the plug to the bottom of the trans. Then get a 80-90w gear oil and a PUMP. The refill on mine was 100cc. I used ratio-rite to measure the 100cc of oil and then pumped it into the trans. Pretty simple operation really, take about 15 minutes. Good luck.
flyin-lowe
Dec 1, 2017 03:18 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
bigbear350quad
Sep 11, 2015 12:40 PM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
