front tires on a 650 p
Old Jan 25, 2005 | 09:32 AM
MoosEye's Avatar
Default front tires on a 650 p
A friend of mne has a 2002 650 prarie. He wants to upgrade his tires but is cautious about getting the front to big that they will rub something. Does anyone have any experience in this area? The tires he wants on the front are a little wider and 1" taller than stock.
I know the newer models are comming out with 26s on them, but will a one number wider tire cause a problem?
Thanks
Old Jan 25, 2005 | 07:17 PM
littlecanuck74's Avatar
i have a 700 kawi and i have 27 10 12 in the front and 27 12 12 in the back with no problems at all these tires actually came off my 650 praire with the same out come put the tires on that you want and keep making the holes too big for the other guys
Old Jan 25, 2005 | 11:58 PM
bogtrotter's Avatar
I am running a 2003 650 P with 26x12x12 rear and 26x9x12 fronts, (Bear claws) no problems except that they are harder on gas and drive belts than stock tires. Only to be expected becuase they are heavier and have greater rolling resistance. On the other hand, they don't get stuck easily and will cross logs and ford holes better.
Old Jan 26, 2005 | 12:11 AM
rivermud's Avatar
My 02 prairie has 26x10x12 front and 26x12x12 rear for mud. If you want it more for speed,playing or trail riding I would stick with the 25s though. It steals alot of power.
Old Jan 27, 2005 | 09:38 PM
KawZark's Avatar
My buddy and myself have '02 P650s...we went with Goodyear Mudrunners (runflats) and stayed with the 25" because of the added weight. They are a great match for the quad and we don't have to worry about flats when riding the rocks/mud/everything else at places like Hatfield. You might want to check them out...they wear like iron.
Old Jan 27, 2005 | 10:24 PM
Gougeonit's Avatar
'02 P650 with 27x9x12 front & 27x11x12 rear Titan 589's the only rub i get is on the fuel tank cover when i run 'zero' air pressure in the rear.
Reactant
Mar 30, 2022 02:08 AM
baysport
Jul 23, 2015 11:37 AM
rcappie4
Jul 18, 2015 07:51 AM
JackTheKing
Jul 14, 2015 09:09 PM
tporath
Jul 11, 2015 12:31 PM
