installing front sprockets
Old Jan 31, 2005 | 05:12 PM
Rockinfigs's Avatar
Default installing front sprockets
im getting a 12 tooth sprocket and want to know if i need any special tools to install and can i use the stock chain?
Old Jan 31, 2005 | 05:48 PM
Raptorboy4life's Avatar
no need for special tools... Ratchet and sockets! If yo uhave the size big enough?
Old Jan 31, 2005 | 09:31 PM
Rockinfigs's Avatar
anyone know the torque specs on the nut holding the front sprocket...i cant seem to find it in my service manual.
Old Jan 31, 2005 | 09:43 PM
70 Nm (7.0 m - kg, 50 ft- lb)
Old Feb 4, 2005 | 04:34 PM
Rockinfigs's Avatar
cool..thks, now does anyone know where i can get some detailed info on how to install a front sprocket on a raptor.?
Old Feb 4, 2005 | 05:29 PM
CTracingraptor's Avatar
First take off that cheap plastic case saver, if im right its a 32mm nut, my advice would be use a impact gun to get it off, but before you do bend the tabs on the nuts down!!. Put your bike in 3rd gear, have your buddy press on the rear brake, and bump the nut off, its easy as that. If your adding a bigger sprocket youll prob have to add a link to make it fit. Its really east though.
Old Feb 4, 2005 | 06:19 PM
Rockinfigs's Avatar
cool thks CT..can i just put the emergency brake on and can i use the stock chain? im going down to 12 tooth. thks
Old Feb 4, 2005 | 06:31 PM
fastblaster00's Avatar
just tighten the chain. since its a 04 raptor the chain shouldnt be to loose to run the ajuster back enough.
rcappie4
Jul 18, 2015 07:51 AM
95wolv
Jul 17, 2015 08:13 PM
joeyupton
Jul 14, 2015 11:51 AM
tporath
Jul 11, 2015 12:31 PM
Mphillips
Jul 2, 2015 07:20 PM
