Not Going into Reverse
Old Jan 31, 2005 | 07:34 PM
mmoulder's Avatar
Default Not Going into Reverse
I have an 05 Arctic Cat 400 4x4 that won't shift into reverse anymore. It does every once in a while, but not most of the time. Anybody have any advice to fix the problem? It started a little while ago, and would go in sometimes if I pushed really hard down, but now it doesn't.[img]i/expressions/face-icon-small-sad.gif[/img]
Old Jan 31, 2005 | 08:53 PM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
It takes a while to brake these things in, try giving it a little throttle, and that should do the trick. After you get more miles on the thing, it will be a lot easier. If this doesn't work, take it back as it would need to be adjusted. Good luck!
Old Jan 31, 2005 | 09:31 PM
megspop's Avatar
I had the same problem when I first got mine....A little throttle, as previously stated, was all mine needed at first, now it's no problem.
Old Jan 31, 2005 | 10:40 PM
Bear4570's Avatar
Before my first oil change my H/L/R shifter wouldn't give me Low or Reverse. The nut had come off the shift rod hiem joint. Tighted the nut and still wasn't right. Took it in for oil change and they adjusted the linkage under warrantee. I'd take it to the dealer if you are not a mechanic. Mine was so new they just fixed it.
Old Feb 1, 2005 | 09:44 AM
catrep's Avatar
If you have a 05, you have the 2 yr warranty. Take it back to dealer and let them adjust or fix it.
Old Feb 7, 2005 | 03:12 PM
Nats's Avatar
Old Feb 7, 2005 | 03:16 PM
Nats's Avatar
I had the same problem. I am taking to dealer under warrantee to fix. I do not know what the root cuase is but that is why they have service techs![img]i/expressions/face-icon-small-wink.gif[/img]
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
poutlaw525
Sep 9, 2015 03:19 AM
