Bushing on Cover Plate (drive pulley)
Old Feb 3, 2005 | 06:02 PM
kodiac1's Avatar
Default Bushing on Cover Plate (drive pulley)
Old Feb 3, 2005 | 06:17 PM
kodiac1's Avatar
Oops...hit the wrong key[img]i/expressions/face-icon-small-blush.gif[/img]...I am in the middle of replacing the bushings in my drive and driven pulleys.I only have 1200 miles on mine and the bushing in the drive cover plate and the inner one was way out of spec.Mine had started knocking louder and I suspected this was the issue.The shoes are fine.I know alot of people think the knocking is the shoes but in my case they are not worn at all.Just an FYI.I maintain mine and and was surprised they were so bad.I was able to grab my drive pulley assy while still bolted to the crank and litterally move it up and down,to me that sloppy enough to affect the moveable sheave to where it will be at a bad angle against the belt and affect performance and belt wear.The outer bushing is only serviced with the cover so I took it to a machine shop and they are making one out of OILLITE for alot less than the $83.00 the dealer wants.ALso,there are three diff covers so you have to figure out which one you have if you go that route.Eeverone may want to keep and eye on this while doing belt adjustments...just an FYI
02 650 camo
Old Feb 3, 2005 | 10:44 PM
sledgehammer650's Avatar
Thanks kodiac mine dodne the same tihng around 1500 miles but it was to far gone asnwell as the clutch sheeves so had to replace. mike said that at one point or another i got water/dirt in there.
Cummins Driver
Sep 11, 2019 01:22 PM
mdrkcckv
Jul 22, 2015 09:10 AM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
clsharky
Jul 13, 2015 02:07 PM
