AWD Problems
Old Feb 12, 2005 | 03:58 PM
rucky's Avatar
Default AWD Problems
AWD doesn't seem to be working. Checked all the fluids and are OK. Speedo is working OK. When in 2-wheel drive AWD indicator flashs . Diagnostics though the Pod shows power getting to the coils. What could be the problem? Or what next?
Old Feb 12, 2005 | 04:11 PM
SPORTSMAN70003's Avatar
Have you changed the fliud it might have water in it. It also might be eletircal since it is flashing. maybe someone that had the same problem will chim in. Also welcome to the forums.
Old Feb 12, 2005 | 04:25 PM
rucky's Avatar
Thanks for the info I'll check front hubs for water and replace oil if needed thanks!!!
Old Feb 12, 2005 | 05:00 PM
silverbullet2005's Avatar
sounds like maybe water/moisture problem to me. oh and a second welcome to the forums.
Old Feb 12, 2005 | 06:27 PM
rucky's Avatar
Thanks for your reply. Just replaced oil in both front hubs and still nothing. At least I know now that part is OK. I ordered a service manual from Anderson Cycle today. Maybe can get other ideas in there. I live in Waterford, MI. Thanks again, rucky
Old Feb 12, 2005 | 10:31 PM
RobRuf's Avatar
I don't know if the Sportsmen are the same or close to the Magnums but my Speedo was blink to show a "fault" in the system. Turns out my CDI box was fried and it would blow out the fan sending unit. With my CDI box bad the AWD was toast. Like I said I don't know is the Sportsmen is the same or close but it might be another place to look...
Old Feb 12, 2005 | 11:09 PM
rucky's Avatar
Thanks for the info. They could be the same. I'll check that out next. Thanks!!
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
