TB tranny woes....and which spring?
Old Feb 13, 2005 | 10:03 PM
02TrailBlazer's Avatar
Default TB tranny woes....and which spring?
Well I found my problem with my 02 TB tranny. My sons friend revved it to the moon and jammed it in gear, breaking all the dogs off of the forward engagement sprag in the tranny. I removed the trans which took about 4 hours not including the hour I went riding my sons CRF150 just to get a break. I took my time and it was a straightforward job. Once I got the tranny drained and the case broke apart, the chunks from the sprocket felt out in my hands. Needless to say I was pissed.
Anyways...my belt looks OK. No dryrotting or excessive wear that I see....should I replace it anyways or can I reuse the old one. Also I am concidering replacing the clutch spring. My bone stock bike has a blue spring. Which replacement color spring would be good to pep up a stock TB? Also does anyone know if the bearings are pressed on the drive shaft? I see snap rings on them but it looks as if they may be pressed on. I still have to remove that old sprag in order to put the new on.
Old Feb 13, 2005 | 10:25 PM
jeffro206's Avatar
the bearings are a machine fit. they're not pressed really hard. sometimes with 2 ppl, you can use a punch or something and a hammer and get them off. have had a few that needed pressed, but not many. as far as the spring, there are sevral to choose from. for a step up from stock a polaris plain like in the 500 scram, or the polaris black. check out the aftermarkets, aaen, hpd, hsp, all have springs.
Old Feb 14, 2005 | 07:59 AM
ftwflh's Avatar
DITTO on the tranny bit I would go with the Polaris white spring it is the stock spring from a 400 TB or 400 Scrambler.
Old Feb 14, 2005 | 11:06 PM
jeffro206's Avatar
yea thats what i meant was the white or plain, some are plain with a whit dot or line, on the 400. 500 i think uses the blue. sorry
Old Feb 15, 2005 | 07:22 PM
So what will changing to a white spring do in terms of performance for my stock Trailblazer? Also should I change out the belt even though it looks decent?
Old Feb 15, 2005 | 08:00 PM
jeffro206's Avatar
it will give you a little more rpm at engagement and through the shift out. makes the bike feel alittle snappier on throttle. hey how do you like your '05 150?
Old Feb 15, 2005 | 08:14 PM
The 150 is a blast. Im a big boy ( 250 lbs ) and it pulls me around pretty well. Its my sons bike BTW.
Old Feb 15, 2005 | 08:43 PM
jeffro206's Avatar
i was just wondering about it, because a few friends ride bikes and quads. they keep telling me to get one. im not that much of a bike person, mostly rode theirs, 250 4stk yammy, and crf250 honda. they're alot of fun but i dont need anything that big to ride and have fun on. thanks
shimanok2
Jan 29, 2016 07:37 PM
brinkkl2000
Oct 16, 2015 11:08 AM
Logan Collins
Sep 5, 2015 08:03 PM
Haakon
Aug 24, 2015 01:54 PM
Mphillips
Jul 2, 2015 07:20 PM
