Recon Problems
Old Sep 20, 2000 | 08:03 AM
recoman's Avatar
My 2000 Recon died on the trails last night. The only way it would start was with the choke all the way out and at full throttle. Motor was hot. Any ideas as to what went wrong all the sudden?
Old Sep 20, 2000 | 08:58 AM
WV250R's Avatar
If the only way it will start is with the choke all the way out, then your engine isn't getting enough fuel the normal way. Most likely dirt or obstruction in the carb jets. You should remove & clean carb, but I've seen a few folks get lucky by opening the carb drain, turning on the fuel & working the throttle. What your doing is trying to flush that piece of dirt, grass, whatever, out of the carb. Good Luck!
Old Sep 20, 2000 | 10:30 AM
TPnTX's Avatar
did u hit any water b4 it died?
Firefighter400
Oct 8, 2022 06:38 PM
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
hondarider1234
Jul 21, 2015 11:53 PM
MNatv89
Jul 7, 2015 11:36 AM
