Fuel type
Old Feb 20, 2005 | 05:29 PM
JkAss's Avatar
Default Fuel type
I've been running 110 octane leaded racing fuel, due to my setup, per Duncan Racing. Now I'm changing my setup. Was running a 40 mm flat slide Mikuni with a twist throttle and going to a 38 mm Keihin Air Styker with a thumb throttle. Motor has a 330 big bore kit. The engine is ported and polished. Can I use unleaded pump gas 91 octane with trick additive or will it mess up my engine because it has already been running leaded 110?
Also, what reeds would work best with my new setup? Just pulled mine out they are thrashed!!! Broken ends and kind of fried.
JkAss
Old Feb 20, 2005 | 07:30 PM
maddog56's Avatar
Default Fuel type
Compression and timing will determine your octane, the carb you use doesnt make a difference. Additives are worthless, if you need high octane then run it.
Old Feb 20, 2005 | 07:34 PM
JkAss's Avatar
Default Fuel type
How can I figure out my compression?
Old Feb 20, 2005 | 07:45 PM
maddog56's Avatar
Default Fuel type
Go to an auto store or a sears type store and pick up a compression tester.
Old Feb 21, 2005 | 01:38 AM
JkAss's Avatar
Default Fuel type
OK
gogogo
Oct 15, 2015 05:40 PM
gogogo
3) General Discussions..
Sep 8, 2015 08:49 PM
bradco
Aug 21, 2015 08:11 PM
Aitch
Jul 21, 2015 09:40 PM
Ask the Editor
12
Jul 21, 2015 06:57 AM
